faliaga
Mar 13, 2020Aspirant
VLAN Status shows non member ports
Hello. I already searched all the web but I can't find a solution. After configuring some vlan's for some LAG's, and then removing those vlans from each switch ports, VLAN status still shows some ...
DaneA
Mar 15, 2020NETGEAR Employee Retired
Welcome to the community! :)
What is the current firmware version of the M4300-28G switch? If its not yet the latest version, I suggest you to update it. The latest firmware version is v12.0.9.4 and you can download it here. Then, observe if the same problem occurs.
DaneA
NETGEAR Community Team
