faliaga
Mar 13, 2020Aspirant
VLAN Status shows non member ports
Hello. I already searched all the web but I can't find a solution. After configuring some vlan's for some LAG's, and then removing those vlans from each switch ports, VLAN status still shows some ...
DaneA
Mar 19, 2020NETGEAR Employee Retired
Thank you for your feedback. As far as I have checked, there is no issue logged on the M4300-28G as per described on your post. A way to double-check if the same settings are still applied is by checking it via console connection to the M4300-28G.
Since you deleted the VLAN and re-configure the setting which fixed the problem, if ever the problem occurs again, I suggest you to open a chat or online support ticket with NETGEAR Support at anytime.
DaneA
NETGEAR Community Team
faliaga
Mar 19, 2020Aspirant
Thank you DaneA
Finally I configured the switch via ssh. There using cli commands I "fixed" the config making it the same as shown in the web gui. As this is a production (and only) switch, after fixed the config for one interface member of a lag, then I disable/enable the interface to "load" the new config. One by one interface.
So switch "fixed"... and learned that the Netgear M4300-28G has "two running configs".. one it's the web one and the other the "internal" one :S Anoying.. Hope Netgear will fix this in the future.
Thank again,
Fernando.
- Retired_MemberMar 23, 2020
Hi faliaga
For the two questions your mentioned:
i) How to make both the same? ii) And how to remove from the web gui, for example, vlan 66 from port 1/0/10?
Item1: For web GUI, go to 'Switching->VLAN->Advanced->VLAN Membership' page, then select VLAN ID to 60, you will see the port 1/0/10 is marked with 'T', that is mean this port is tagged to VLAN 66;
Item2: If you want to remove the port 1/0/10 from VLAN 66, please click the 'T' to blank. Then the port will be removed from VLAN 66 success;
And the CLI configration file should be same as web GUI display.
Hope it helps!
