faliaga
Mar 13, 2020Aspirant
VLAN Status shows non member ports
Hello. I already searched all the web but I can't find a solution. After configuring some vlan's for some LAG's, and then removing those vlans from each switch ports, VLAN status still shows some ...
faliaga
Mar 19, 2020Aspirant
Thank you DaneA
Finally I configured the switch via ssh. There using cli commands I "fixed" the config making it the same as shown in the web gui. As this is a production (and only) switch, after fixed the config for one interface member of a lag, then I disable/enable the interface to "load" the new config. One by one interface.
So switch "fixed"... and learned that the Netgear M4300-28G has "two running configs".. one it's the web one and the other the "internal" one :S Anoying.. Hope Netgear will fix this in the future.
Thank again,
Fernando.
Retired_Member
Mar 23, 2020Hi faliaga
For the two questions your mentioned:
i) How to make both the same? ii) And how to remove from the web gui, for example, vlan 66 from port 1/0/10?
Item1: For web GUI, go to 'Switching->VLAN->Advanced->VLAN Membership' page, then select VLAN ID to 60, you will see the port 1/0/10 is marked with 'T', that is mean this port is tagged to VLAN 66;
Item2: If you want to remove the port 1/0/10 from VLAN 66, please click the 'T' to blank. Then the port will be removed from VLAN 66 success;
And the CLI configration file should be same as web GUI display.
Hope it helps!
