KelvinFu
Apr 25, 2018Aspirant
VoIP Setting in multiple switches scenario
Hi All,
We are currently implementating an IP Phone project which requires me to modify the setting on core switch (M4300 x 2 stacked) and Smart Layer 2 switch (GS752TP), I did have some resear...
JohnC_V
May 08, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
