agbn
Apr 23, 2024Aspirant
VRRP configuration
Hi, Please help me to configure vrrp on M4350 with multiple vlan . Thank you
schumaku
Apr 24, 2024Guru - Experienced User
Your schema does show a stacked pair of two M4350, and a set of GS7xx PoE switches in a combination (like a poor-men's-stack), each with a redundant set of connections in a LAG.
Don't want to start a philosophic discussion on stacking vs. MLAG however:
What for do you plan to use VRRP for? Any security appliances or routers for handling multiple Internet connections around this for example not on the schema?
- agbnMay 28, 2024Aspirant
Hi,
Thanks for the update. I am new to VRRP. My requirement is redundancy with minimum cost.
Please find the attached design and please recommend stacking ,MLAG or VRRP.
Thanks in advance.
- ErwinLSep 06, 2024NETGEAR Moderator
Hi agbn
And welcome to the NETGEAR Community! 🙂
Maybe you could start understanding how this works on our switch from the link below and you will see few links at the bottom of the page are some of our articles about VRRP configuration that might help.
Have a lovely day,
Erwin
Netgear Team
