phenderson's avatar
phenderson
XS728T DHCP relay support?
I recently purchased a XS728T to replace an old Cisco 2950.  After setting it up, I don't see a way to setup dhcp helper/forwarding on this switch.  Am I missing something?  My dhcp server is able to serve the vlan it's on but none of the other vlans are able to send requests to it.
Thanks!
  • It's realY an oddity  the XS708T, XS712Tv2, and XS716T for example have the DHCP Relay feature, while the MS510TX or XS728T/XS748T for example don't have it.
  • schumaku's avatar
    schumaku
    • phenderson's avatar
      phenderson
      Thanks for the info!  It's a nice switch, so it seems really strange that it wouldn't have that feature.
      My LAN has ~15 vlans, so I really need this.  Do you happen to know of any workarounds to get it working without getting a different switch?
      I'm struggling to find another switch that has everything I need: 24 ethernet, minimum 2 SFPs, VLAN support and dhcp relay.  Do you happen to know if Netgear has a switch with those capabilities in a similar price range?
      Thanks again!
      Phil
      • Retired_Member's avatar
        Retired_Member
        phenderson
        I was in the same position with my MS510TX and MS510TXPP switches. My solution was to buy a couple of CISCO CBS350 switches (considerably less expensive) and demoting the NETGEAR switches to the L2 position where they really belong to.
    • schumaku's avatar
      schumaku
      schumaku wrote:
      It's really an oddity  the XS708T, XS712Tv2, and XS716T for example have the DHCP Relay feature, while the MS510TX or XS728T/XS748T for example don't have it.
      YeZ can't a DHCP relay feature be enabled on these models now?
ProSupport for Business
