gorkatjimmies
Jan 11, 2023Aspirant
XS748T - LAG question
I have 2 Link Aggregations set on my switch. One is 2 10Gpbs ports and another is 4. The first connects to a Freenas box and the second to a Linux box. Both boxes have a LAG set up of 2 or 4 ports...
schumaku
Jan 12, 2023Guru - Experienced User
Check if the bonding interfaces are active ....
[~] # ifconfig -a | grep bond
grab the output using e.g.
cat /proc/net/bonding/bond0
cat /proc/net/bonding/bond1
- gorkatjimmiesJan 16, 2023Aspirant
Thanks for that. I am struggling to be able to logon to the switch remotely. I have enabled remote admin but cannot get the switch to accept a telnet connection. I'll let you know when I get those commands properly executed.
- schumakuJan 16, 2023Guru - Experienced UserThe commands show apply to a Linux Binding system, not to the switch.
- gorkatjimmiesJan 17, 2023Aspirant
This is the output for the two interfaces. lagg0 is on a freebsd box and team0 is on a Rocky linux box.
lagg0:
flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=e407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether a0:36:9f:3f:b3:8c
inet 10.0.9.31 netmask 0xffffff00 broadcast 10.0.9.255
nd6 options=9<PERFORMNUD,IFDISABLED>
media: Ethernet autoselect
status: active
groups: lagg
laggproto lacp lagghash l2,l3,l4
laggport: ix0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: ix1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
team0:
flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.9.32 netmask 255.255.255.0 broadcast 10.0.9.255
ether 84:16:0c:c4:b6:10 txqueuelen 1000 (Ethernet)
RX packets 20807488 bytes 379816736216 (353.7 GiB)
RX errors 0 dropped 345 overruns 0 frame 0
TX packets 11810865 bytes 1788077637 (1.6 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
