ElmerFudd66
Aug 17, 2023Aspirant
XSM7224S - 24-Port 10G SFP+ Receive Discards On Port Channel
Morning, We have 2 of the above stacked. There is a port channel configured with 4 ports 1/0/23 and 24, 2/0/23 and 24 these are connected to a L2 Dell N4032F We have been seeing a large volume o...
schumaku
Aug 17, 2023Guru - Experienced User
ElmerFudd66 wrote:
Morning,
Good morning 8-)
ElmerFudd66 wrote:
Swapped out the SFP on 1/0/24, the receive discards then stopped.
However, they then started on 2/0/23 which was previously error free.
Defect SFP module moved probably. Have properly cleaned the fiber connection (module and cable)?
- ElmerFudd66Aug 17, 2023Aspirant
I thought the SFP was faulty too, so swapped it.
What I dont understand is 1/0/23 was showing Receive discards, I swapped the SFP in 1/0/24 and the receive discards have stopped on both the above interfaces, we didn't touch 1/0/23.
It's as if the issue has moved to switch 2 in the stack, but neither of those 2 interfaces were touched either.
- JulienRAug 18, 2023Administrator
Hi ElmerFudd66,
I will get a member of our support team to contact you and log a case.
Thank you.
Best Regards,
Julien R.
