PESE's avatar
PESE
1000/100mbps in, 735 mbps from router and 94mbps from switch GS105E!?
My internet provider (Hiper) delivers 1.190mbps (download) into my house via coax. Approx. 735 mbps is sent on from the router (SagemCom F@ST 3890V3 WU also provided by Hiper) via approx. 5 m cat6 to...
  • schumaku's avatar
    Aug 01, 2020
    Lot of loss already, ok, might be caused by the "best effort" policy in place on consumer connections, or related to the asymmetric speed.
    PESE wrote:
    From here approx 95 mbps is delivered from any of the output ports.
    Reads like there is a link in the data path operating at 100 Mbit/s link speed only.
    PESE wrote:
    In the Insight app, where I can manage the switch, in the port status it is stated, that all 5 ports are up, speed is auto, linked speed is 1000M on port 1-4, and no more than 100M on port 5
    What is connected to this port #5 - the link to the modem/router?
    PESE wrote:
    ...100M on port 5 (and I can't change that myself)?
    Perfectly correct - automatic link speed negotiation is mandatory on Gigabit and faster Ethernet links. Fixing to link rates of 1000M and up is illegal, this is why Netgear does not offer this control option.
    Try a diffeent cable. Check and clean the contacts if required, ... Typical cause for 100M only are not four pairs propery wired on the cable(s). Auto negotiation are very uncommon nowadays, but still exist.
ProSupport for Business
