Fred9's avatar
Fred9
1000BaseT SFP for GS752
I have been trying to find a compatible 1000BaseT SFP (Cat 6 copper EN) for our GS752. I want to use the SPF ports to trunk our GS752 to a GS724 in another room using CAT6 cabling.
I've tried several different AGM734 compatible SFPs but none of them will bring a link up. My mode of testing is to connect two of the SFP equipmented ports on the GS752 here with a short, Cat 6 ethernet cable. The ports seem to sync for a short time about 1 second and then go down. They repeat this forever. Here's the current SFP that I can currently using:
https://smile.amazon.com/gp/product/B073W4MVD6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Can someone help me to find an SFP that will work for this application or perhaps point me to a configuration problem on our switch?
  • schumaku's avatar
    schumaku
    To start with, please provide exact GS728T[P|X]xxxx resp. GS752T[P|X]xxx model and the currently installed firmware version. Far to many different GS728/GS752 models.
    In general, Netgear does only support the official Netgear SFP (resp. SFP+ models for 10G and multigig).
    "Compatible" does indicate (by most alternate vendors) that maker, model, and ID is configured similar to official modules - no warranty it does work with each and every model combination.
    • Fred9's avatar
      Fred9
      My GS752 is the original version with V6.0.1.29 installed. S/N - 3AS4795R00156.
      • Fred9's avatar
        Fred9
        If there is an official Netgear 1000BaseT module for my switch, how can I go about purchasing them? I can't see to find source for anything but the compatible versions from other vendors.
ProSupport for Business
