jrhoops
Jan 02, 2018Aspirant
10Gbase-SR Netgear to Cisco connection
I have an XS708T with AMX761 10g-sr module and want to connect to a cisco switch. I have two modules for cisco and two modules for netgear along with 2 cables. I have verified the cisco switches can...
- Jan 03, 2018
I actually got this sorted out. The issue is the modules only want to initiate when connected to the same exact make/model transceiver. You can trick it if you have multiple modules inserted but luckily the netgear switch also support the cisco compatible module so i was able to identical modules in each switch.
jrhoops
Jan 03, 2018Aspirant
Hopchen
Jan 03, 2018Prodigy
Hi again,
I am glad you got it sorted :)
Please consider marking this thread as resolved. Cheers!
