andrevanm
Jan 04, 2021Aspirant
2nd GS308 managed switch does not get an IP
Hello, Forgive me if I ask something very obvious or something impossible. This is my situation. I bought a second GS308T switch to extend my network. The first one connected to my router already h...
- Jan 06, 2021
Exchanged to new devices, or A-B to B-A?
Ensure both switches are operating on the current firmware -> GS308T | Smart Managed Pro Switch | NETGEAR Support - as of writing it's 1.0.1.2 (don't be confused with 1.0.0.12).
Do a factory reset if the status is potentially unclear or undefined.
Perform a Cable Test on both switches...
DaneA
Jan 05, 2021NETGEAR Employee Retired
Welcome to the community! :)
Is the 2nd GS308T directly connected to the 1st GS308T? If yes, what is the color/behavior of the port LED lights connecting the 2nd GS308T and 1st GS308T?
What is the current firmware version of the 1st and 2nd GS308T switches?
Are there VLANs configured on both 1st and 2nd GS308T switches?
DaneA
NETGEAR Community Team
andrevanm
Jan 05, 2021Aspirant
Thanks for your reply DaneA. I appreciate it very much.
Concerning your questions:
>Yes
>1st GS308T: once in a while blinking orange shortly
>2nd GS308T: green and blinking
>1st GS308T: I think same as 2nd switch as it is brand new.
>2nd GS308T: Boot version: 1.0.0.1 Software version: 1.0.0.12
>No
- schumakuJan 05, 2021Guru - Experienced User
andrevanm wrote:If yes, what is the color/behavior of the port LED lights connecting the 2nd GS308T and 1st GS308T?
Something wrong there.
Tried a different cable?
Tried a different port for the link on either of the two switches?
- andrevanmJan 05, 2021Aspirant
Thanks Schumaku for your suggestion.
I don't think it is the cables as when I connect the cable to the second switch (remove it from the switch) and connect it to my computer, I do have proper connection. I also tried different ports but to no avail.
So test different port on the other switch.
I need to make a correction. The led on the 2nd switch is once in a while orange, not green.
