andrevanm
Jan 04, 2021Aspirant
2nd GS308 managed switch does not get an IP
Hello, Forgive me if I ask something very obvious or something impossible. This is my situation. I bought a second GS308T switch to extend my network. The first one connected to my router already h...
- Jan 06, 2021
Exchanged to new devices, or A-B to B-A?
Ensure both switches are operating on the current firmware -> GS308T | Smart Managed Pro Switch | NETGEAR Support - as of writing it's 1.0.1.2 (don't be confused with 1.0.0.12).
Do a factory reset if the status is potentially unclear or undefined.
Perform a Cable Test on both switches...
andrevanm
Jan 05, 2021Aspirant
Thanks for your reply DaneA. I appreciate it very much.
Concerning your questions:
Is the 2nd GS308T directly connected to the 1st GS308T?
>Yes
If yes, what is the color/behavior of the port LED lights connecting the 2nd GS308T and 1st GS308T?
>1st GS308T: once in a while blinking orange shortly
>2nd GS308T: green and blinking
What is the current firmware version of the 1st and 2nd GS308T switches?
>1st GS308T: I think same as 2nd switch as it is brand new.
>2nd GS308T: Boot version: 1.0.0.1 Software version: 1.0.0.12
Are there VLANs configured on both 1st and 2nd GS308T switches?
>No
schumaku
Jan 05, 2021Guru - Experienced User
andrevanm wrote:If yes, what is the color/behavior of the port LED lights connecting the 2nd GS308T and 1st GS308T?
Something wrong there.
Tried a different cable?
Tried a different port for the link on either of the two switches?
- andrevanmJan 05, 2021Aspirant
Thanks Schumaku for your suggestion.
I don't think it is the cables as when I connect the cable to the second switch (remove it from the switch) and connect it to my computer, I do have proper connection. I also tried different ports but to no avail.
