arthurjohnston
Dec 31, 2021Aspirant
5-Port Gigabyte Switch (managed)
Does the GS105Ev2, switch allow me to route incoming traffic to a specific Port only? Specifically, route to a Web server.
arthurjohnston
Jan 01, 2022Aspirant
Can anyone list model numbers of Lan Routers that will serve my purpose.
The reason, I am in the community asking this question, is I recently purchased and returned 2 NetGear routers, becuase they did not contain the features I am seeking (LAN Router Configuration) . The most recent was a Nighthawk AC 1200, that is solely a WIFI Router.
Help!
schumaku
Jan 01, 2022Guru - Experienced User
Netgear offers DSL routers (xDSL WAN/Internet connection), Cable Router (Cable TV Modem serving WAN/Internet connection to the TV network ISP), Mobile Routers (with 3G/4G/5G mobile network WAN/Internet connection), normal "routers" (with an Ethernet port for the Internet/WAN). Except of the portable Mobile Routers, all offer typically four Ethernet LAN ports. There are also other devices like WiFI extenders under the Nightawk logo ...
Far to many my friend Arthur. All the ones linked under the three categories above are such routers currently available from Netgear.
The reason, I am in the community asking this question, is I recently purchased and returned 2 NetGear routers, becuase they did not contain the features I am seeking (LAN Router Configuration). .
Difficult to check the devices in question without the excat model designation.
Hardly think there is a pure routers with an Ethernet WAN port and only WiFi. Be aware that most modern routers in this consumer market are supporting WiFi _and_ LAN ports, but are designated as a WiFi router. For example the "AC1200 WiFi Router Dual-Band WiFi Router (up to 1.2Gbps) - Long range coverage, high performance", Model R6230 - a WiFi router, one Gigabit Ethernet WAN/Internet port, four Gigabit Ethernet LAN ports. The feature you are behind is shown in the user documentation as "Port Forwarding to a Local Server". Example: AC1200 Smart WiFi Router with External Antennas Model R6230 User Manual p.119 ff. Note: This feature exists on virtually all router types.
Before ordering the next router, please let us know about your Internet connection, the Internet bandwidth you intend to subscribe (or the max the ISP does offer). This has an impact on the router.
Beyond, in many case there are ISP supplied CPEs which serve as a WiFi (and LAN router), too - most offer the same port forwarding feature, too. And adding a second NAT router in the data path will be cumbersome.
In general, more and more ISP don't assign public routeable IPv4 addresses to the Internet service connections (the number of available IPv4 addresses is simply limited and not an endless resource - this is sufficient to surf the Internet, to do downloads. Like a phone number you can call out, but you can't be called. For serving a reachable IPv4 address on a port forwarding, you need a routeable public Internet connection. On some services you can request this, other ISPs are adding an additional charge or offer this feature with business class connections only.
