tahiti25
Nov 03, 2017Aspirant
Accidentally disabled admin on all ports GS110tp
I am new to this forum so please be patient. I had to disable all ports which were connected to wireless radios for a 3rd party firm to access and service there equipment neighbouring ours, however I...
- Nov 09, 2017
Thanks for the update. I'm glad that it worked after doing a factory reset. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Nov 06, 2017NETGEAR Employee Retired
Welcome to the community! :)
I'm afraid that we need to perform a factory reset on the GS110TP switch then reconfigure the settings from scratch since there is no way to manage the GS110TP switch anymore because all ports were disabled accidentally.
DaneA
DaneA
Nov 09, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
- tahiti25Nov 09, 2017AspirantYes thanks, factory reset worked.
- DaneANov 09, 2017NETGEAR Employee Retired
Cheers,DaneA
