bwc_bl3h
Dec 21, 2020Initiate
ACL failing on Smart Managed Pro switch
Hello,
I am trying to create an ACL that will allow HTTP access to a web server on TCP port 80 from anywhere and to TCP port 9999 from internal network only. The server is on switch port 8. I started with the wizard and added sequence 3 in advanced. I am using this:
Sequence 1:
Action: Permit
Match Every: False
Protocol Type: 6 (TCP)
Destination L4 Port Action: Equal
Destination L4 Port: www-http
Sequence 2:
Action: Permit
Match Every: False
Protocol Type: 17 (UDP)
Sequence 3:
Action: Permit
Match Every: False
Source IP Address: 192.168.69.8
Source IP Mask: 0.0.0.255
Destination L4 Port: 9999
In the wizard I click bind to switch port 8 and save and I can no longer visit the server in a browser on 80 nor telnet to port 80 or 9999 (all is working before ACL put in place).
Please let me know how I can set this up correctly, thanks!!
I was adding the ACL to the port the www server was plugged into - this was the error. The rules only apply to INBOUND traffic - I applied the rule to the port that the cable modem is plugged into and it filtered exactly as expected for the www server.
1 Reply
- bwc_bl3hInitiate
