erkr
May 07, 2019Follower
Add tab to Show MAC table on ProSaf Plus switches, please!!!
Hi
I own 3 Netgear ProSafe plus switches (GS108Ev3 running V2.06.03) and for network maintenance I try to check the MAC table to trace where devices are located.
Please add a MAC table tab like ...
- May 07, 2019
The Smart Managed Plus switches like the GS108E are built on "non-managed" switch cores paired with a simple controller allowing to do some limited settings only. Details like a MAC table are not even accessible to the controller.
These switches are coming on a very different price tag - almost on the level of a non-managed switch - than the Web managed Smart Managed Pro models like the GS108T.
schumaku
May 07, 2019Guru - Experienced User
