MLVoDaVi
Jul 24, 2023Follower
Adding VLAN
Good morning, I am having issues setting up a VoIP VLAN. I have the VLAN Tagged on the interface connecting to the firewall. I have the VLAN Tagged for all uplinks to other switches that will be h...
schumaku
Jul 24, 2023Guru - Experienced User
A little bit vague of what you like to achieve with the VoIP VLAN in general, and what exactly you expect for the switch ports for IP-phones and/or for generic data devices.
Start about here: How do I set up a VOIP VLAN in Insight?
- a01Aug 08, 2023Guide
Are the ports connecting to the phones untagged and the same VID is set as the PVID?
