monnier
Aug 11, 2021Aspirant
Administration POE
Hello, When I want to configure the POE, I have a message loading page and that's it. the display is not done. So I can't configure the POE Best regards
schumaku
Aug 12, 2021Guru - Experienced User
monnier Does the switch power a 802.11afv or a .11at PD?
Remeber havibg seen sich an issue on a PoE dwotch with a defective PoE unit.
monnier
Aug 19, 2021Aspirant
Hello,
I don't know,
where can I find this information
I have a NETGEAR 48-Port Gigabit PoE+ Smart Managed Pro Switch with 4 SFP Ports (GS752TPv2)
