ShawnSpencer's avatar
ShawnSpencer
WAX601 PoE
Hi
I am looking for the right Netgear Switch that goes with the WAX6, because mine does not work (does not have PoE+).
Would that be an option?
https://www.netgear.com/business/wired/switches/plus/gs308epp/
Any suggestions or other options?
Thank you for your help
  • schumaku's avatar
    schumaku
    Jul 26, 2023
    ShawnSpencer wrote:
    ... I have a Netgear GS108T-300PES (8 Ports) and it does not work with the WAX610 (PoE not sufficient).
    The GS108Tv3 (GS108T-300PES) is a 8-Port Gigabit Ethernet Smart Switch with optional Cloud Management, and has no PoE capabilities. You might have the option to add a power supply near to the WAX610 installation point.
    ShawnSpencer wrote:
    If I want a managed one then it would be the Netgear GS308EPP-100PES - correct?.
    The GS308EPP is a 8-Port High-Power PoE+ Gigabit Ethernet Plus Switch with some configuration features.
    The Smart Switch counterpart would be the for example the GS110TPv3 — 8-Port Gigabit PoE+ Ethernet Smart Switch with 2 SFP Ports and Cloud Management
  • schumaku's avatar
    schumaku
    To power the WAX610, a PoE switch with 802.3at is sufficient. Considering possible bandwidth for the WAX610 is going beyond a simple Gigabit Ethernet 2.5Gbps PoE port might be considerable. From the pure PoE requirements view, the unmanaged GS308EP could be sufficient.
    • ShawnSpencer's avatar
      ShawnSpencer
      Thank you very much
      I ask because I have a Netgear GS108T-300PES (8 Ports) and it does not work with the WAX610 (PoE not sufficient).
      So I am looking for the best replacement for it.
      Thanks for help
      • schumaku's avatar
        schumaku
ProSupport for Business
