RGoemie
May 20, 2017Follower
Advanced 802.1Q VLAN Configuration not working
I tried to setup a 802.1Q trunk between the netgear switch and an Intel NUC running as a VMWare ESXi server. On the switch, i configured 2 VLAN IDs, 1 and 10. The trunk port on the switch is member...
- Jun 04, 2017
I just want to follow-up on this. Were you able to try our suggestion? if yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
May 23, 2017NETGEAR Employee Retired
Hi RGoemie,
Welcome to the community! :)
It seems that your concern is similar to this link I found online. Kindly try to set the port of the GS116Ev2 switch where the Intel NUC is connected as untagged port.
Let us know the result.
DaneA
XavierLL
HI RGomie,
Totally agree with DaneA the issue is that ESXi uses VLAN 1 as a Native VLAN so by default untagged.
Just wanted to add to DaneA that in your case you should configure the VLAN 1 as Untagged (double click on the port) and the other VLANs as tagged.
Hope it helps
Xavier Lleixa
NETGEAR CBU PLM
