LibTech009
Apr 20, 2021Aspirant
all of my switches use 169.254.0.239
I have several GC728X switches, most 28 port, a few 52, firmware v1.0.5.32. All list their connected neighbor switch as the same IP that appears in the Mangment IP for all devices. Except 2 GC108...
LibTech009
Apr 28, 2021Aspirant
Can anyone tell me why, if there is no DHCP on my network and the switches are configured with static IP, does the port connecting the backbone devices default?
schumaku
Apr 28, 2021Guru - Experienced User
Probably not. Wild guess something like a random config reload, which does fail at some point - before the management IPs are set again. Or some part of the config are skipped or error-out...
- LibTech009May 18, 2021Aspirant
Still looking for assistance with the issues involving default Management IP use when configured with Static IP.
- schumakuMay 18, 2021Guru - Experienced User
Can't see another way but open a support ticket. Wild guess your GC7xx switches don't boot completely, error-out at some point, or some cloud config (being on dynamic) does overwrite a local config, .... or simply the network isn't ready before the management IP does fall-back to the default before the DHCP is reachable.
- LibTech009May 19, 2021Aspirant
trying to figure out how to get Insight subscription for support.. seems the last gy in charge let it run out last year and the apps says you have to go thru 3rd party..? otherwise it looks like Gearhead is 150$ a year per device...?!?!?
