GaACETech
Dec 16, 2020Guide
Basic Config - Layer 3 Switch
I have two of the GS716v2 that I need to install in a temporary work area for employee's. About 10 people per switch plus a SonicWall SonicWave AP (only 3 users will use Wifi). These switches conn...
- Dec 16, 2020
All these switches come out of the box with a flat L2 network config. bandwidth requirements permitting one fiber link per switch is sufficient - there you go.
I would ensure the switches are managed resp. secured. Take control, change the default password, configure a static IP or set-up a MAC-IP reservation on the DHCP server so the switches can be reached and monitored at least, configure SNMP security or disable it.
schumaku
Dec 16, 2020Guru - Experienced User
- GaACETechDec 17, 2020Guide
You mentioned disabling SNMP. To do thta change the status of the public and private entries to 'disable'?
Thanks,
Darryl
- schumakuDec 17, 2020Guru - Experienced User
The idea was to put up secure comunity strings and not use the default public ones. Sorry for the poor wording.
