GaACETech
Dec 16, 2020Guide
Basic Config - Layer 3 Switch
I have two of the GS716v2 that I need to install in a temporary work area for employee's. About 10 people per switch plus a SonicWall SonicWave AP (only 3 users will use Wifi). These switches conn...
- Dec 16, 2020
All these switches come out of the box with a flat L2 network config. bandwidth requirements permitting one fiber link per switch is sufficient - there you go.
I would ensure the switches are managed resp. secured. Take control, change the default password, configure a static IP or set-up a MAC-IP reservation on the DHCP server so the switches can be reached and monitored at least, configure SNMP security or disable it.
GaACETech
Dec 17, 2020Guide
You mentioned disabling SNMP. To do thta change the status of the public and private entries to 'disable'?
Thanks,
Darryl
schumaku
Dec 17, 2020Guru - Experienced User
The idea was to put up secure comunity strings and not use the default public ones. Sorry for the poor wording.
