dtmoc
Jul 28, 2022Aspirant
Basic Help - VLAN Config with Router DHCP-DNS
Hoping I can get some insight and this is the FIRST time I have looked at VLAN options. Switch is JGS516PE - 16-Port Gigabit Ethernet PoE Smart Managed Plus Switch The scenario is a small ne...
schumaku
Jul 29, 2022Guru - Experienced User
Does this router support the configuration of multiple networks, IP subnetworks, and DHCP for each, e.g. on a per port or VLAN level?
I fear this is where many first adventures end. Most consumer routers, ISP supplied end-user routers, and so on don't support this.
- dtmocJul 29, 2022Aspirant
Hey schumaku
Thanks for taking the time to post.
Well - that could certainly be the problem!!
Definitely, there is only a single IP range supported in the router.
Was actually expecting devices to work within the one DHCP range but just not have access to ports not tagged with the same VLAN assuming of course the DHCP device port was tagged for the vLAN. Sigh...
For vLAN configs then is it always necessary to have a front end router that support multiple DHCP Scopes and vLANs in order for vLANs to work? (It's funny how many articles focus on configuring the switches and do not mention supporting hardware needed.)
