colligo
Oct 12, 2017Follower
Best Practices for Configuring Switch Connected To Internet
Model: GS105Ev2 Firmware: V1.5.0.4 Hi there! Our internet provider has provided us with 3 static public ip addresses along with their internet cable modem. I've connected the internet cable mo...
- Oct 16, 2017
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Oct 13, 2017NETGEAR Employee Retired
Hi colligo,
Welcome to our community!
As per checking in here that you do have a GS105Ev2 on which is just a Prosafe plus switch. No additional configuration needed to ensure the best performance and security of this device. Actually you may just connect all the firewall appliance and set each with its own IP and you're now good to go. Unless you maybe needing to have a port-based VLAN to ensure that this will not communicate to each other.
