joey_gs724's avatar
joey_gs724
boot code update
i have a negear prosafe GS725T switch with the oldest firmware on it and i would like to update it to newest firm but in order to do so i need to update the boot code first but i am unable to find an...
  • JohnC_V's avatar
    JohnC_V
    Jul 29, 2019
    joey_gs724,
    That's correct. Most of the firmware has its own boot code file.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    JohnCarloV
    NETGEAR Community Team
ProSupport for Business
