tomrdodge's avatar
tomrdodge
GS724TS: Unable to Upgrade Boot Code
Hardware Version:  00.00.01
Boot Version:  1.0.0.07
Software Version:  v3.1.0.1
I am aware of the instructions which include the step:  Select Firmware > File Management > File Download.
BUT my firmware does not have those options.
I have also tried using a tftp server.  I am able to upload the configuration, but I am unale to download.
So, how do I install boot code version 1.0.1.5 ??
  • Hi tomrdodge,
    Welcome to the community! :)
    Kindly access the article below and follow the steps:
    Updating Boot Code via TFTP
    Let us know the result.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi tomrdodge,
    DaneA
    • tomrdodge's avatar
      tomrdodge
      That solved it.  Everything is now updated.  Thanks for the help.
      What I think I learned:
      1.  SmartWizard does not work for boot upgrades.  The TFTP process is required.
      2.  The TFTPD32 application worked fine as a local TFTP server, with the one caveat that it has to be closed and restarted again after every reboot of the GS752TS inorder to re-find everything.
      3.  After a boot upgrade, a software reset is not sufficient.  A power-off reboot is required.
      4.  For the Firmware upgrades, SmartWizard works well, and it automatically resets the switch after the upgrade.
ProSupport for Business
