tomrdodge
Apr 03, 2017Aspirant
GS724TS: Unable to Upgrade Boot Code
Hardware Version: 00.00.01 Boot Version: 1.0.0.07 Software Version: v3.1.0.1 I am aware of the instructions which include the step: Select Firmware > File Management > File Download. BUT m...
- Apr 04, 2017
Hi tomrdodge,
Welcome to the community! :)
Kindly access the article below and follow the steps:
Let us know the result.
DaneA
NETGEAR Community Team
DaneA
Apr 04, 2017NETGEAR Employee Retired
Hi tomrdodge,
DaneA
tomrdodge
Apr 06, 2017Aspirant
That solved it. Everything is now updated. Thanks for the help.
What I think I learned:
1. SmartWizard does not work for boot upgrades. The TFTP process is required.
2. The TFTPD32 application worked fine as a local TFTP server, with the one caveat that it has to be closed and restarted again after every reboot of the GS752TS inorder to re-find everything.
3. After a boot upgrade, a software reset is not sufficient. A power-off reboot is required.
4. For the Firmware upgrades, SmartWizard works well, and it automatically resets the switch after the upgrade.
