joey_gs724
Jul 22, 2019Aspirant
boot code update
i have a negear prosafe GS725T switch with the oldest firmware on it and i would like to update it to newest firm but in order to do so i need to update the boot code first but i am unable to find an...
- Jul 29, 2019
That's correct. Most of the firmware has its own boot code file.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
joey_gs724
Jul 24, 2019Aspirant
hi and thanks for responding to me.
i am not intending on jumping firmware versions but go in a ladder fashion. if i understand you correctly, i can upgrade my firmware untill i am presented with more features in the web gui to upgrade the boot code?
so this is directly copied from the switch browser admin dashboard. i am not sure what version is the switch exactly and i wont have physical presence to the hardware untill a few days but it maybe v1. btw i did a reset so all configuration info is from a reset .
Product Name GS724T Firmware Version V1.0.0_0429 Protocol Version 2.001.002
JohnC_V
Jul 25, 2019NETGEAR Employee Retired
I can't seem to find the right model for your device. I assume this is a GS724Tv2. The boot code is included in the zip file once you downloaded the posted firmware in our downloads page. You may need to update the boot code first before proceeding further.
JohnCarloV
- joey_gs724Jul 25, 2019Aspirant
right so i already have that zip file but what i am not understanding is how is the boot code uploaded to the switch? there is no directions provided in that zip other than "make sure ot upgrade boot code" .... i found some other directions but that was for GS724v4 which has different features which mines lack in the webui.
- JohnC_VJul 26, 2019NETGEAR Employee Retired
You may upload the boot code on the same application where you upload the firmware. You may need to use the Smartwizard Utility in order for you to upgrade it.
Here is the reference(page 5-1).
JohnCarloV
- joey_gs724Jul 26, 2019Aspirant
thanks it seems to work for the first upgrade version i did so far.... do all firmware upgrades require bootcode to be upgraded prior firmware upgrade? it seems all zip files have a bootcode file.
