joey_gs724
Jul 22, 2019Aspirant
boot code update
i have a negear prosafe GS725T switch with the oldest firmware on it and i would like to update it to newest firm but in order to do so i need to update the boot code first but i am unable to find an...
- Jul 29, 2019
That's correct. Most of the firmware has its own boot code file.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
joey_gs724
Jul 26, 2019Aspirant
thanks it seems to work for the first upgrade version i did so far.... do all firmware upgrades require bootcode to be upgraded prior firmware upgrade? it seems all zip files have a bootcode file.
JohnC_V
Jul 29, 2019NETGEAR Employee Retired
JohnCarloV
