OrbiPhilip
Nov 30, 2020Luminary
BPDU/STP Errors
I am experiencing BPDU/SPT errors on from my Orbi. This causes my Netgear GS324 switch to lock out the port administratively. To recover I must then manually re-enable the port. The Orbi is conne...
OrbiPhilip
Dec 01, 2020Luminary
My apologies, you are correct. the device is a GS324T S350 Series 24-Port Gigabit Ethernet Smart Managed Pro Switch
Orbi is
Hardware Version RBR50
Firmware Version V2.3.5.30 / GUI Language Version V1.0.0.375
It was working previously, with a Cisco SRW2024 switch. No idea if STP was enabled as the console never functioned properly and I used it as if it was a dumb switch. The port being disabled begain with the GS324T.
OrbiPhilip
STP Config is as follows:
- FURRYe38Dec 01, 2020Guru - Experienced User
Use the Choose File button on your post to attached the picture file. Forum mods have to approved embedded pictures.
- schumakuDec 01, 2020Guru - Experienced User
Can't see the in-line image yet. For the moment, please try to disable STP.
- schumakuDec 16, 2020Guru - Experienced User
The other possible approach is completely disabling STP (read also no RSTP or MSP) and enable the "Forward BPDU while STP Disabled"
