OrbiPhilip
Dec 01, 2020Luminary
BPDU/STP Errors
I am experiencing BPDU/SPT errors on from my Orbi. This causes my Netgear GS324 switch to lock out the port administratively. To recover I must then manually re-enable the port. The Orbi is conne...
OrbiPhilip
My apologies, you are correct. the device is a GS324T S350 Series 24-Port Gigabit Ethernet Smart Managed Pro Switch
Orbi is
Hardware Version RBR50
Firmware Version V2.3.5.30 / GUI Language Version V1.0.0.375
It was working previously, with a Cisco SRW2024 switch. No idea if STP was enabled as the console never functioned properly and I used it as if it was a dumb switch. The port being disabled begain with the GS324T.
Dec 01, 2020Guru - Experienced User
Check the IGMP setting on these switches. Been said to disable this helped correct wire connected RBS to these switches between the RSS and RBR.
Test a non managed switch if you can to compare...
You a little behind on FW. v16 works well with ethernet connected RBS and non managed switches.
