NobleSpartan117
Oct 14, 2018Tutor
Cable Modem, Switch, and Wireless Router
I'm trying to figure out how to setup my network. I have the following equipment:
-Arris SB8200 cable modem with 1GB internet
-Asus AC-5300 wireless router
-Netgear GS752TPP
I'm wonderin...
- Oct 16, 2018
Link aggregation between router and switch allows your devices to treat multiple Ethernet links as if they were a single link to increase bandwidth or provide fault tolerance. To set up link aggregation, you must create a link aggregation group (LAG) on both devices. Link aggregation between your ASUS router and your GS752TP switch offers increased bandwidth over a link of up to 2 Gbps.
ASUS router LAG port 1 and 2 Dynamic Link aggregation (802.3ad)
NETGEAR GS752TP switch the LAG Type should be change from Static to LACP.
Nodism1125
Oct 15, 2018NETGEAR Expert
Hi NobleSpartan117,
I would recommend this type of network setup (first method).
Cable modem -> ASUS Router -> Switch (GS752TP)
If ASUS router support Link Aggregation (LAG), you can connect 2 switch LAN ports as uplink to router.
Please note that you need to check what type of LAG support the ASUS router either Static LAG or LACP. The GS752TP should both LAG type.
schumaku
Oct 15, 2018Guru - Experienced User
Hi Nodism1125, What for a LAG switch<->router if there is just a single GbE Internet connection?
