watchheirmc
Mar 11, 2018Aspirant
GS108PEv3 setup question - broadband modem -> switch -> wireless AP
Hi all, I purchased a GS108PEv3 with the plan to set it up in a broadband modem -> switch -> wireless AP configuration. The broadband modem is an Alcatel-Lucent i040g-p. (Not receiving a static ip from the ISP)
I tried playing with the ip settings and the DHCP enable/disable mode but couldn't get internet access working. The modem is connected to the switch and is visible in Prosafe utility, via a laptop connected to another port.. When trying to access it via the utility there is an error message though, saying that the switch and and the management ip are not in the same subnet.
Just wondering if this config is possible and if so what are the settings?
Appreciate your help.
Watchheirmc
Is there a way to make the GS108PEv3 work as a router?
On the box it has a picture of it connected to a 'WAN' somehow.
It is not possible to make the GS108PEv3 switch work as a router.
The GS108PEv3 has a default IP address of 192.168.0.239. You will need to change its default IP address to an IP address that is within the IP range of your LAN so that it will be accessible within your existing network.
Here are the steps below:
1. Disconnect the GS108PEv3 switch from your existing network. Connect a PC to a LAN port of your GS108PEv3 switch.
2. Set a static IP address of 192.168.0.210 to your PC.
3. Open a browser like Google Chrome or Firefox then at the address bar of it, type 192.168.0.239 then press Enter. Login to the user interface of switch. Enter "admin" and "password" as the username and password respectively without the quotation marks.
Note: The default IP address of GS108PEv3 is 192.168.0.239.
4. The Switch Information page displays. In the DHCP Mode menu, select Disable.
5. Enter a static IP address that is within the IP range of your existing network in the field provided (for example: 10.0.0.9). Also, enter the corresponding subnet mask and default gateway then click Apply.
Note: You will lose access to the web-GUI of the GS108PEv3 because you have just change its IP Address which is normal.
6. Connect a LAN port of the GS108PEv3 to your router.
Note: Double-check if your Alcatel-Lucent i040g-p is a combination of modem and router. If ever it is just a modem-only device, you will need to purchase router and deploy it between the Alcatel-Lucent i040g-p and the GS108PEv3 switch.
7. Set your PC/laptop to "Obtain an IP Address Automatically." Then connect it to a LAN port of the GS108PEv3.
8. Open a browser like Google Chrome. Then, at the address bar of it, type the static IP Address you have set to the GS108Ev3 then press Enter. If you are able to access it, then it means that the GS108PEv3 is now a part of your existing network.
Note: You may also perform a connectivity test. Open command prompt on your PC/laptop then ping the static IP address you have set to the GS108PEv3. If you receive replies then it means that the GS108PEv3 is reachable within your existing network.
DaneANETGEAR Community Team
- I can't find any information about the Alcatel-Lucent. Is it a pure modem or a combination modem/router?
If it's a pure modem, then you need a router to go between it and the GS108PEv3. The GS108PEv3 is a switch, not a router.- watchheirmcAspirant
Thanks for your reply.
I am not quite sure myself whether it is a modem or modem/router.
Also how does the DHCP mode enable/disable function works? The manual just tell you to toggle it between 'browser access', 'Prosafe utility access', etc.
Thanks
No. What we call a "router" in the home networking market is actually a combination of devices: a firewall, NAT, router, DHCP server, Wi-Fi Access Point and switch. The GS108PEv3 is just a switch. It is a smart switch but not in ways that grant it the capabilities of any of these other devices found in a "router".
The DHCP mode here is a DHCP client function. You may be confusing it with a DHCP server function. A DHCP server hands out IP addresses to clients. If you disable DHCP on the switch, then the switch will not dynamically acquire an IP address from a DHCP server. Instead, you must manually configure an IP address on the switch itself.
Can you clarify what the model of the Lucent-Alcatel modem is? There's no mention of i040g-p anywhere on the Internet. Try looking for a label on the modem.
- jonathan_lNETGEAR Expert
Hi Watchheirmc,
I would suggest to connect a PC directly to Alcatel-Lucent i040g-p to check if internet is working. ISP might reserved some LAN ports on broadband modem for IPTV access only.
Jonathan
Thanks The internet and wifi does work, when the modem is connected directly to the wireless AP.
