bob_smith123
Jan 27, 2022Aspirant
Camera/NAS VLAN on GS728TPv2 not working
Hello, I have a GS728TPv2 and would like to set up a VLAN for my POE cameras and NAS. I would like the NAS to be able to access the internet so I can view the camera streams and recordings and wo...
JeraldM
Jan 28, 2022NETGEAR Employee Retired
Welcome to the community!
Perhaps what you'll need to do is to have a traffic rule set on your firewall to block incoming traffic from the WAN going to the IP addresses of your cameras.
JeraldM
NETGEAR Community Team
- bob_smith123Jan 28, 2022Aspirant
Hello, thank you for the reply. This same exact setup worked perfectly with a smaller plus managed switch without needing to change firewall or router settings. Is there a reason why it is not working with the GS728TPv2 switch?
- schumakuJan 29, 2022Guru - Experienced User
Yes. The config isn't a plain VLAN design strictly isolating the VLAN. Much more it is an Asymmetric VLAN config. The odd thing is that all the UIs allow this [in strict IEEE 802.1q sense] invalid config.
- bob_smith123Jan 29, 2022AspirantThank you for the reply. Is there a way to make the Asymmetric VLAN config work on this managed switch? Do you have a recommendation for the correct VLAN and PVID assignments for the ports? Or are there other steps needed to make it work? Thanks!
