SteveFcKay
Oct 14, 2022Aspirant
Can a GS752TX stack with a S3300-28X?
I don't want to get rid of my G752TX but I need to 10G stack it - will it work with a S3300-28X in a stack or at 10G?
- DaneANETGEAR Employee Retired
Welcome to the community! 🙂
You can stack the S3300-52X (GS752TX) switch with an S3300-28X (GS728TX) switch via the 10G SFP+ or 10GBASE-T copper (both at 10G speeds) ports. You can stack up to six (6) S3300 switch models. If you are going to use the SFP+ ports for stacking, be sure to use the compatible SFP+ modules for the S3300 switch models.
To know more about the specifications and compatible SFP+ modules for the S3300 switch models, kindly access and read its data sheet here.
DaneA
NETGEAR Community Team
- SteveFcKayAspirant
Thanks for the reply, but just to clarify, my GS752TXS does not have any RJ45 Copper 10G sockets, just SFP+. It is not the same as an S3300-52X. Will it still stack?
The GS752TXS switch is NOT compatible to be stacked with any S3300 switch model like the S3300-28X or S3300-52X. It is because the GS752TXS switch and S3300 switches have different firmware version and hardware platform.
You can stack the GS752TXS with another GS752TXS or GS728TXS. A stack can contain a mix of up to six GS728TXS and GS752TXS switches. As reference, read page 8 of the GS728TXS/GS752TXS Hardware Installation Guide here.
DaneA
