DeeDee123
Nov 06, 2022Tutor
Can bootloader be updated? Netgear Switches
Hi, I have multiple GS108Ev3 switches that have different bootloader versions. How can I update them all to the latest? I also have a GS110EMX switch and a XS716T switch that I would like to ...
microchip8
Nov 06, 2022Master
Are you actually trying to fox some problem or are you just concerned about bootloader versions?
No, to my knowledge, you can't update the bootloader on switches.
DeeDee123
Nov 06, 2022Tutor
Hi, not concerned. Just wanting to use latest version and found it odd that the same model switches use different versions and saw no way to update them.
