axt
Dec 22, 2015Aspirant
Can I connect 802.3AF devices to my GS510TP
HI, I have Access Ponits that support the 802.3af standard and am not sure if I bought a GS510TP that I can safely connect thses AP's to the POE+ ports. In the past I have connected these AP's to...
- Dec 22, 2015
Hello axt - Steve,
The GS510TP does support devices using 802.3af (DTE Power via DMI). You can adjust and configure each port on how you want the PoE to play out. See screenshot below:
I hope this helps, let us know if you have more questions.
Thanks,
JohnRo
Dec 22, 2015NETGEAR Employee Retired
Hello axt - Steve,
Thanks,
