explainmethis
May 19, 2021Aspirant
Can you recommend a PoE passthrough device?
Hi, I have a single ethernet port in my office which has PoE power coming to it (the port is fed from a 24-port PoE switch in another room). Is there a device I can use to split the PoE port in m...
- May 19, 2021
One of the very few devices allowing this is the Netgear GS105PE. Keep in mind PoE is strict class oriented (scratch any math of my AP does use say 12.7W and the like), if you need to operate a 802.11af Class 0 access point along with the switch which requires some power, too, you need a 802.11at (PoE+) power source from the existing switch.
FMI: https://kb.netgear.com/25541/GS105PE-PoE-troubleshooting - reading and understanding is mandatory.
