cfrudolphy
Mar 23, 2023Aspirant
Can you "stack" these two Netgear Switches or "Trunk" them
I own a JGS516PE and a GS724T V2. I currently have a flat network 192.168.1.0/24. My network has grown to the point (also includes ip cameras and many IOT devices) where I think I should segment th...
schumaku
Mar 26, 2023Guru - Experienced User
cfrudolphy wrote:
3.) If not "stackable" as described above (which is what I assume) should I create identical vlans on both switches, i.e. VLAN 20 IOT devices on both switches as necessary?
Yes, of course. It's possible to connect multiple switches, and manage oe or more VLAN. Keep in mind the trunk can be done using all tagged ports, or tagged and one untagged network for management simplicity. Don't forget to configure the PVID on the ports you want untagged frames on to be assigned to the correct VLAN intended.
