Rostam
Feb 07, 2022Tutor
Cannot create backup from NETGEAR GS724T configuration.
Hello, I cannot create backup from NETGEAR GS724T configuration. Get an error Can anyone help please? Thanks
- Mar 14, 2022
I found a way to fix the issue. I had to use old versions of Internet Explorer to be able to do that.
Thank you!
DaneA
Feb 08, 2022NETGEAR Employee Retired
What is the current firmware version of your GS724T?
To backup the configuration file from the GS724T, on the web-GUI, go to Maintenance > Upload > HTTP File Upload. On the File Type list, select Text Configuration and click Apply.
To restore the configuration file to the GS724T, on the web-GUI, go to Maintenance > Download > HTTP File Download. On the File Type list, select Text Configuration. Then, click the Browse button to locate the configuration file and click Apply.
DaneA
NETGEAR Community Team
