Rostam's avatar
Rostam
Tutor
Feb 07, 2022
Cannot create backup from NETGEAR GS724T configuration.
Hello, I cannot create backup from NETGEAR GS724T configuration. Get an error Can anyone help please? Thanks
  • Rostam's avatar
    Rostam
    Mar 14, 2022
    I found a way to fix the issue. I had to use old versions of Internet Explorer to be able to do that.
    Thank you!
ProSupport for Business
