AntC
Feb 26, 2025Aspirant
Cannot Download Config for GS728TP
Hello, I'm trying to download the configuration of my Netgear GS728TP, but every time I try, I get "Failed - Network error" message. Searching the web, I find a lot of people have had this issue...
akispel
Jul 27, 2025Aspirant
I had the same issue, always got a “Failed - Network Error” no matter what browser or setup I used.
What finally worked was using Microsoft Edge with Internet Explorer mode enabled. I added the switch's IP under the IE mode settings, and then the config download worked perfectly through the web interface.
Hope this helps.
