iSCUBA4sharks
Oct 30, 2017Aspirant
Cannot install Smart Control Center due to Bitlocker
SCC version: release v1.1.3.4 firmware version: (2.0.1.26 - ultimately, I'm trying to upgrade to 2.0.1.40) OS: Windows 10 There seems to be an issue with the installer not playing nice with Bit...
- Nov 05, 2017
The JGS516PE switch has a default IP address of 192.168.0.239. This is indicated on the JGS516PE user manual here on page 8. Hope that you were able to read that part since I gave you the pages that you have to read in on how to Access and Configure the switch using a Web Browser or using the ProSAFE Plus Utility.
It would be best if you will assign a static IP address to the JGS516PE switch that is within the IP range of your existing network for ease of management. Here are the steps below:
1. Disconnect the JGS516PE switch from your existing network.
2. Connect a PC directly to a LAN port of the JGS516PE switch. Just the PC and the JGS516PE switch connected to each other.
3. Set a static IP address of 192.168.0.210 to your PC.
4. Open a browser like Google Chrome or Firefox then at the address bar of it, type 192.168.0.239 then press Enter. Login to the user interface of switch. Enter "admin" as the username and "password" as the password.
Note: The default IP address of JGS516PE is 192.168.0.239.
5. The Switch Information page displays. In the DHCP Mode menu, select Disable.
6. Enter the IP Address that you want to assign to the JGS516PE switch that is within the IP range of your existing network as well as the Subnet Mask, and Gateway Address of your existing LAN network on the fields provided.
7. Click Apply.
Note: As soon as you click Apply, you will lose access to the JGS516PE switch. Set the PC back to 'Obtain an IP Address Automatically' or set a static IP address on the PC that is within the IP range of your existing network.
As reference to the steps above, kindly read pages 14-15 of the JGS516PE user manual here on how to assign a static IP address to the JGS516PE switch.
DaneA
NETGEAR Community Team
DaneA
Nov 01, 2017NETGEAR Employee Retired
Hi iSCUBA4sharks,
Welcome to the community! :)
As far as I have checked, there is no issue logged about Smart Control Center not being installed properly because of BitLocker as per described in your initial post. Kindly try to disable BitLocker for the meantime then try to install again the Smart Control Center.
You have specified that you have a JGS516PE switch. Be reminded that the Smart Control Center is not compatible to the JGS516PE switch. The Smart Control Center is used for NETGEAR Smart Switches like the GS108Tv2 or GS110TP switches.
The ProSAFE Plus Configuration Utility is compatible to the JGS516PE switch. You can download the latest version of the ProSAFE Plus Configuration Utility here then install it in your PC.
Furthermore, the JGS516PE can be managed either via its web-GUI using a browser or using the ProSAFE Plus Configuration Utility. Kindly read pages 7-10 of the JGS516PE user manual here on how to Access and Configure the switch using a Web Browser or using the ProSAFE Plus Utility.
DaneA
DaneA
Nov 05, 2017NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
