Philip_Sta
Jan 14, 2022Tutor
Cannot login - IP address
I have installed my switch about 2 years ago and wanted to access it again to deploy the latest firmware however I do not manage to access it through my browser via the standaard IP address that is indicated on the device...it shows an error message "this site can't be reached" - "ERR_CONNECTION_TIMED_OUT". Anyone who can help?
You model modem has a built in router and wifi. What mode is the modem working in? Modem only mode or router mode. If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
have you logged into your router to check to see if the router assigned it a different ip address?
Or used the switch discovery tool from the support site?
https://www.netgear.com/support/product/JGS516PE.aspx#download
are you running a double nat? (more than 1 router device)?
The switch is on a different subnet that the device you're trying to access from.what router do you have?
What modem/gateway are you connected to?
If the switch is connected to the gateway and the router/devices to a different that'll cause issues.
A double nat happens when you cascade more than 1 router.
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
