xben1298's avatar
Apr 10, 2019
Can't disable STP from LAG on GS752TP
Hi everyone,   I want to configure a LAG between a gs752tp  and a JGS524Ev2 in this discussion it was pointed out that the STP has to be disabled on the lag to not create a storm.  https://comm...
  • schumaku's avatar
    schumaku
    Apr 12, 2019
    While it's a little bit odd that STP can't be disabled on that LAG (looks like a UI bug) - I'm doing hard to understand on how the STP BPDU should cause havoc on the network. Probability? Very near to zero.
    Double check your network patches configured as static LAG are on the correct ports as configured to be LAG members. Then there won't be any loops.
ProSupport for Business
