xben1298
Apr 10, 2019Tutor
Can't disable STP from LAG on GS752TP
Hi everyone,
I want to configure a LAG between a gs752tp and a JGS524Ev2 in this discussion it was pointed out that the STP has to be disabled on the lag to not create a storm.
https://comm...
- Apr 12, 2019
While it's a little bit odd that STP can't be disabled on that LAG (looks like a UI bug) - I'm doing hard to understand on how the STP BPDU should cause havoc on the network. Probability? Very near to zero.
Double check your network patches configured as static LAG are on the correct ports as configured to be LAG members. Then there won't be any loops.
xben1298
Apr 12, 2019Tutor
Hi schumaku,
For some reason my reply didn't go trought.
I did try the LAG and it did kill my network has stated in the other tread.
I probably tried everything to get the STP Disabled on the LAG including ( change ports, disable admin, try another borwser even, LCAP instead ) Nothing works that seems to be a bug. I also updated to the latest firmware and still can't changes.
Thanks for the help.
Cheers
schumaku
Apr 12, 2019Guru - Experienced User
