el_pedro
Oct 03, 2022Aspirant
Can't log into GS724TPV2 browser interface after Insight subscription lapsed
My trial Insight subscription has lapsed and now I can't log into the browser portal of my GS724TPV2 switch because I do not know the password. Neither 'password' nor '1234' work. I vaguely recall t...
- Oct 04, 2022
Welcome to the Community!
Once you add a device to a network location through the NETGEAR Insight app or portal, you will have to use the admin password for that Insight network location even when logging in to the local GUI.
Have you tried using that password set on Insight? You should be able to manage the switch thru the local GUI even without Insight.
HTH
Marc_V
Oct 04, 2022NETGEAR Employee Retired
HTH
