Compendic
Oct 12, 2021Aspirant
Can't reach GS748T Web UI outside of local network
Hello community, I have a GS748Tv5 switch on a particular network, along with a GS724TP. They have separate IP addresses (obviously) on the same network and both have the same (correct) router co...
schumaku
Oct 13, 2021Guru - Experienced User
Compendic wrote:
--- It looks like it's starting to, and part of the page seems to come across, but not enough ever loads to display anything but a blank page on my screen. I can ping the switch just fine; I just can't manage it through HTTP or HTTPS.
For some context, the "outside" address I am trying to access the switch through is on the other side of a site-to-site VPN established by the router. ...
The only other thing I can think of is that it might be something related to MTU, but there doesn't seem to be any way to set MTU in the GS748.
Perfect problem analysis - must be an MTU (and PTMUD) handling problem on this switch model management IP stack.
YeZ please push this to the switch engineering for an urgent fix.
-Kurt
